Leon Sheean
After replacing the "O" rings on the hatch 'dogs' the smaller (13 x 17 inch) forward hatch is still leaking. The leak seems to be coming around the gasket between the metal frame and the (intaact/non-cracked) gasket. Is it possible to carefully remove the gasket from the acrylic lens, and re-seal it to the lens? If so, how?! If not, where is a source of replacement gasket material?
Thank you.
Thank you.
