Hello all, the jaws on these antique winches are so worn they will not hold the line consistantly anymore. A simple replacement set of jaws seems to not exist anywhere. Any suggestions?
Lewmar º 48000449 34ST/40ST Jaw Kit. LH: 76327142. Die auf den Batterien abgebildeten Symbole haben folgende Bedeutung: Das Symbol der durchgekreuzten Mülltonne bedeutet, dass die Batterie nicht in den Hausmüll gegeben werden darf.
A search on line for Lewmar winch spares/parts brings up quite a few vendors. You might want to contact several and see if they have the part you need.
Send these guys an email to see if they are still have stock in what you need. They've talked about closing up shop but the website is still active. https://winchspares.com/
