1911tex
The yellow wire with masking tape connects to a purple wire and is also tailed to the Facet electric fuel pump. Seems the yellow wire may be a "test point". Facet works perfectly; however my question: Is this Facet fuel pump connection correct?
Second question: Where does the purple wire go, seems to disappear into the wiring loom going back to the control panel?
