Mast inspection cover
flycavalry
I am considering installing an electrical access plate sold from rigrite to gain access to my wiring just above my mast step on my 30+. The reason for this is because I am not getting power to my foredeck light. I have power to the light inside the boat prior to exiting to the mast step. I am trying to avoid taking down my mast with all the costs and time involved. Has anyone else installed such an inspection cover? It is not a large cover so it needs to be installed where the wires would be best accessed. Would this degrade the integrity of the mast?
Afrakes
Doing this will not cause any structural problems for your mast. It also may not give you enough room to do anything. How old is the mast wiring?
flycavalry
I can only guess that it is as old as the boat, 1984? The mast data plate from Kanion does look like it was made in 1987, so mayne a gew years newer?
goldenstate
My steaming light and foredeck light are an integrated unit with a 3-wire bundle.
1. A shared common/ground wire
2. Positive to steaming light
3. Positive to foredeck light
My take would be, long before you cut a hole in your mast:
Have you gone up in a bosun's chair to look at the fixture(s)?
Is the bulb burned out?
Do you have old wires with bad connections?
I presume you have tested these things.
(I have never had the need to use a foredeck light, but I am a beginner...)
