Hey all, I have a 1969 35 MK 1. I've owned her for 4 years at this point, and throughout that time cracks have started creeping around the base of the deck step. They look uneven compression points, and I've evened out the rigging a few times but they keep creeping.
I covered them with waterproof tape to prevent intrusion and replace it every so often, but would like to fix this long term. Has anyone seen a similar issue? I'm mostly concerned that it could be related to a larger issue with the compression elements that make up the mast step, and would require a more invasive repair than just fiberglass work.
