Robert Trenn
Looking for information from experienced owner (mechanic) about repair of corroded motor base supports.
During a recent inspection before layup I became alarmed about the corrosion on the angle support of my '68 Ericson 30. The piece in question appears to be one of four steel angles running vertical from the hull to the bottom of the base plate which holds the A4. While it is very difficult to get a good view, it seems that repair of the problem is required.
This will, no doubt, require pulling the engine, possibly the fuel tank, and welding re-inforcement to the piece(s) in question.
Has anyone had a similar problem?
