This is from Peggy Hall, posted on the Cruisers Forum. She's the toilet maven and knows more than most of us.
(I wouldn't use 50/50 Muriatic acid in the tank, myself, and would certainly not leave it in the tank more than an hour if I did).
Muriatic (hydrochloric) acid has been the accepted de-scaler for
marine piping and sanitation systems for decades because it does the job without harm to anything in the system including toilets, and it's also safe to use in a metal tank. In fact, it's what
Raritan recommended for
cleaning out the Lectra/San till they decided to add a ready-to-use descaler to their sanitation and cleaning products line.
However, descaling is the ONLY thing that muriatic acid does...and in 25 years I've yet to see a holding tank that has enough mineral buildup in it to need it.
Dirty tank walls are coated with the animal fats in waste, not scale...a strong solution of liquid detergent (Wisk is good...a couple of gallons) in a tank full of
water with a bag full of ice cubes is all you need to cure that problem...go sailing and tack a lot. Then flush VERY thoroughly with clean water.
Sludge, unless it's been allowed to dry and turn to "concrete" can be flushed out with just water (directions to follow)...but if it has turned to concrete, NOTHING will dissolve it that won't damage the system...you're stuck with it. But I've yet to see enough buildup in a tank to block the discharge or make a noticeable difference in the capacity.
The following should be done 2-3x/year, and especially in preparation for winter or other extended
layup:
Pump out the tank, or dump it at sea. Then put enough water into the tank via the
deck pumpout--'cuz that sends the water into the tank at the bottom to stir up the sludge and hold it in suspension so it can be pumped out--to cover the bottom to a
depth of 4-6"...it can be fresh water at the
dock or sea water using a washdown pump. Pump out or dump...repeat...repeat...repeat...till you're pumping or dumping clean water. Then one last time to rinse out any macerator and
plumbing to it.
And while you have the hose in your hand, backflush the tank vent too.
If you're doing this in preparation for winter
layup or extended
storage, this should be done with clean FRESH water and also run through any macerator
overboard discharge
plumbing to rinse them out too.
And with that, my friends, I bid you a fond farewell.
Email me if you need help.
__________________
© 2020 Peggie Hall
Specializing in marine sanitation since '87.
Author "The NEW Get Rid of Boat Odors"
