Puget sailor
As I continue to explore my new 32-3, I’ve come across a few things I’m curious about.
#1. there is a hockey puck sized disc mounted on the steering quadrant, surrounded by 2 hose clamps. At first I thought perhaps it’s a vibration damper, but upon further contorted examination it appears to be a bump stop for limits of travel. My question is, are the clamps supposed to be there, and is it supposed to be hard as a sea-biscuit, or is it supposed to be firm rubber and it’s just become hard with age? I’m guessing the hose clamps were tacked on to keep it from cracking apart because it got hard with age? And if that is correct, any idea where to get a squishy replacement?
Next question, but I think I’ve answered it, what’s the deal with this thing in the aft bilge? It made no sense there until I noticed a spot in the forward galley well that it also fits into. Seems like it’s designed as a sponge and soap tray, but a previous owner decided to shift it to the bilge and added some wood strips in there to hold it. Makes sense, because having it in the galley well wastes a lot of space.
I found this teak gizmo in a storage area, but I can’t tell if it’s a boat part, maybe an obsolete table for the pedestal, an extra step that goes somewhere, but it seems too flimsy, or what? Anybody got one or seen one? Maybe it’s an accessory to the stern tail mounted force 10 gas grill?
Also, both of my lifeline stanchions at maximum beam are bent significantly inward. I’m assuming this is not original, it makes it tough to squeeze past the shrouds especially when scrubbing decks. The posts are straight, and the deck is solid, but the bases look distorted, and resealed. The original Genoa used to hang over the rail here according to some old pictures I’ve found, and the new sail sets higher and does not, so I’m guessing these were purposely shifted inward to improve the set of that old sail. If I’m correct, I will want to dismount the bases and fix them or replace. Any good sources for replacement?
( both sides have similarly bent stanchion bases)
Bonus picture, not a mystery because the creator labeled it, check out this improvised keel bolt socket! It is possible to just buy these now, even extra deep, but perhaps some time ago it was less easy to find on the internet? It’s made from plates welded around a smaller socket!
