I found another oddity with my 36C ('78). I can't seem to find the bilge pump. I see no obvious plumbing to indicate there was one ever installed. I even had a local marine mechanic look around. He couldn't find it either.
I find it odd. If it is there, it is not working and very well hidden. Did they not put in electric/automatic bilge pumps in late 70s? Was it an optional component from the factory?
If I were to install one, I assume it should go in the deepest part of the bilge. However, I would really like to not add an additional through hull. I haven't fully investigated routing for plumbing. Is it okay to join with another system that has a through hull?
Thanks in advance for any info or advice anyone may have.
