___________________
OPENING PORTS. All are Lewmar.
One "New Standard" port installed in 1999, when we added one for the aft cabin area.
This is still a Lewmar current model product, “Size One" , Cutout size is 13 3/4” X 6 3/4”.
Plastic inside trim, in new condition. Note that this port has some slight factory imperfections in the acrylic lens, and they only became noticeable after about ten years. Not a problem, but still not as perfect as their usual product.
Asking $30.
_________________
Two original 1988 Lewmar opening ports. These are Lewmar Old Standard ports.
None of these have leaked, but I have replaced the little turn-lever O rings as needed.
Inside trim pieces, and fly screens included. Perhaps the most valuable parts.
One port has three SS screws that broke off in their frame when I removed them. These will have to be drilled out. Or ignore those and clamp it down with all of the remaining screws; probably work just fine.
Cutout Size for all of these is 13 3/4” X 6 3/4”.
Asking $25. for the good one and "any offer" for the one with the broken screws. (Given that new fly screens list for $39.95, that seems like a good price, but offers will be considered.)
_________________________
Black Anodized perforated Aluminum Toe Rail. Not off an EY model, but I picked it up years ago thinking we might use part of it on the transom top on our boat. Not a good look or fit for our particular boat, upon reflection. Picture in my 12-22-20 ad here.
10’ 8” long. Base is 1 1/2” wide. Outside from bottom to top is 1 3/8” . Attachment holes are industry standard 4” centers , 1/4-20 FH . The slots are 10 1/2” apart. Used but shows well, as salesmen like to say,
It has a slight curve: The radius measure 1 7/16” deflection for every 6’ of length. Experience shows that this product can be forced to be straight or even curve more.
Asking $5. Local pick up only. (Asking pretty much scrap value for it)
One Lewmar D2 Clutch Stopper. Works great but was replaced with a new D2 double recently.
$20.
Harken Traveler and Harken recirculating ball bearing car. This included the factory extension plastic track to move/dismount the car off the track end without losing the bearings.
Track is 4 feet long, 1.25” wide, 3/4” high. Eleven 5/16” bolts on 4” center. Plus two Harken end caps that also thru bolt.
The car is 5.25” long and includes two Harken ball bearing blocks for part of a traveler control system.
Traveler System= $50. Bargain! -just marked down!
T-Track sections. Anodyzed Aluminum. Size= 1 1/4” (long and shorter Genoa tracks, port and starboard)
2 pieces, Merriman 30.5” long each. Originally from Ericson.
2 pieces Merriman 62.5” long each. Originally from Ericson
2 new Garhauer track pieces. Approx 3 feet each.
1 piece (no brand, but it’s new) 21.5” long.
$50. for all. Bargain!
Local pickup preferred, but can ship.
Thank you.
Asking $30.
_________________
$20.
Thank you.
