Stuck Screws
I just had a need to access the guts of my boom. Imagine what 21 years of electrolosis (sp) does between stainless steel, aluminum, and a cast product of something. I had to access the boom so I removed it from the boat, thought about options for a long time, and came up with a plan to solve my issue. At my third attempt, I located a impact driver at ACE hardware ($13.95including 4 assorted tips.) After spending 1.5 Bud lights, I finally figured out how to use it. My process was as follows: beat the offending screw with hammper, scraps crusty looking stuff with ice pic, spray with WD40, and consume .5 Bud light. Then I used the impact driver. (repeat full process as needed. 5 times for each screw seems to work.) Amazing but not without effort, I was able to remove the 3 offending screws.
I fixed the problem with the boom (another thread needed) but the impact driver and my "proven" process worked great.
