Conclusion:
After replacing the glow plugs, tighten the fuel lines, removed and reinstalled the filters, check for any leaks or cracks in the Racor bracket, and countless hours of removal, clean, removed hose clamps / replaced some which I thought they were leaking, removal of the air bleeding valve / cleaned it, air bleeding and starting the engine, it still performed the same. Started up just fine but only when my air bleeder knob was turned open by about 1 1/2 turns, more than that, it stalled and less than that, it stalled.
Until... I was bleeding the air out for the 4th time and my arm rubbed up against the preformed 5/16" fuel line that is about 6", goes from the fuel filter to the air bleeding valve, and when my arm slightly hit the line, a spray of fuel came out and sprayed all over. The preform hose was painted with the engine so you cannot see the crack in the line, even when I removed it - impossible to see it. The hose became very rigid and developed a hairline crack, sucking air into it.... which probably was my problem this summer when I thought my fuel filters were clogged and I did a complete replacement and fuel tank cleaning.
I purchased a 6" long 5/16" fuel line, replaced it, bled the fuel system, etc.... 5 min later after the engine got all the air out, engine sounded better and a little smoother and ran well under load.
Well, although it was frustrating that I could not figure it out sooner, glad I found the problem.
.... Anyone know where you can get the preform fuel line? You have to make a aggressive bend in the line and I can see the line somewhat collapse because of this. It will be fine for some time but I can it being an issue at some point. I looked through the internet and could not find the part.
