dhill
My surveyor commented about the lack of gaskets on my propane locker covers, which are necessary for the propane lockers to be ABYC-complaint. The concern seems to be that despite propane being heavier than air, propane could still get sucked out by a breeze (Bernoulli principle) and blown into the cabin through the companionway. My locker covers each have a hole in the center so you can remove them with your finger, so adding a gasket without closing off the hole would not seem to help much. One could build a shallow enclosure on the back side of the cover behind the hole so you could use the hole to life the cover (need to worry about clearance for the tank) or the hole could be completely closed off while adding some sort of handle that cannot be felt through the cushion.
My surveyor also recommended adding a pressure gauge to help uncover leaks, but there is not a lot of room in the locker and I have yet to find a pressure gauge that will fit without bending propane hoses in precarious ways.
I'm curious what others have done.
Thanks!
Dave
Thanks!
Dave
