Refinishing Opinions Wanted
One of my winter projects is to refinish the companionway steps on my E32-3. I've stripped off all of the old original coating and in the process of doing th final sanding. What are folks using these days for a finish coat? Varnish? Polyurethane? Some varnishes are not recommended for floors. Steps are basically "vertical floors" so those finishes would not be a good choice I suspect. Any recommendations for a finish? I'm thinking semi-gloss or satin since I don't care for a gloss finish below but that's a personal choice I think.
I used two coats of a water based satin polyurethane for my new sole. It’s held up well for 8 years. I assume it would work pretty well on the ladder too.
Pros:
Easy to apply
Doesn’t stink
Cheap
Grippy
Cons:
Doesn’t have the depth of finish like varnish
Here is a photo of the new sole with satin polyurethane and a piece of the old sole with what I assume is gloss varnish but it could be semi gloss. More coats of the polyurethane with fine sanding in between would probably yield a better result but it looks fine as is. Could also go with a semi gloss for better depth. I think the varnish will darken the wood more than the polyurethane too.
My ladder is varnished (Epiphanes high gloss) with new self-adhesive tread tape which I got from the local Ace Hardware, sold by the foot. I prefer varnish because I see maintenance as more predictable with varnish than with polyurethane. I think any coating short of non-skid on the nosing will have the same hazard of slipping, which is why manufacturers would advise against use on floors.
On my E27 this was the case, to the point where I had to apply non skid to the nose. But that terribly abraded my calves when stepping into the cabin! I removed it and learned to tread carefully. No such problems on the 30+ or 34, not sure what was different about the 27. Maybe I’m just older and more cautious with stairs these days.
Pros:
Easy to apply
Doesn’t stink
Cheap
Grippy
Cons:
I understand the pros and cons you’re making. I looked at a photo of my new cabin sole that I finished in my garage (my sole is screwed down with bass “square” screws) and I did it in a gloss varnish. Looks pretty good in the photo but that was two years ago. So for the steps I have changed my mind and I think I will go with a varnish (like I used on the sole) so it’ll match. The foot griping tape will also be replaced too.
I think varnish will look better so agree with your decision. But man, that’s going to be a lot of sanding and detail work with all those angles and corners!
I have had good success in mixing semi-gloss and satin for a nice, non-glare finish on my cabin sole. My handrails used to be high gloss varnish, but last time I mixed half and half with semi-gloss, and it turned out well. I always mix the same brand in case there might be some reaction between brands. Just a thought...
mjsouleman
Mark "Souleman" Soule
Bob,
I am working on cabin sole at this moment. When I bought Sterling II, the Teak and Holly was not finished, just laid down. I put down 3 coats of West Marine 205 epoxy and 206 hardener on all the pieces. Currently I am laying on Totalboat Lust Gloss varnish. I like it because I can put down 3 applications a day.
I am putting off the salon ladder for next years project.
