Hi,
I plan to replace the bellows and O-rings on my dripless shaft seal. I have previously removed the tranny coupler from the transmission to do engine alignment, but it's been 12 years since the tranny coupler was removed from the shaft. It is held in place by two opposing set screws. It looks ok, not rusted, but I'm still concerned I might not be able to remove the coupler from the shaft after I remove it from the transmission. I can't really use tools on the prop shaft for fear of scoring it and thereby damaging the inside O-rings on the stainless flange when I reassemble the PSS shaft seal.
Any advice, tips?
Any advice, tips?
