Replacing a Port Light
view29
I have an Ericson 29, and am looking to replace the original Port Light, Starboard side over the Head (original has a slider). Looking to replace without a slider, so just a typical Port Light. Curious what other folk have done, where they've gone looking etc.
Thanks a bunch!
On the off chance that you want a "modern" opening port, and would be happy with a used port, and the cut out dimensions are appropriate....
check my For Sale ad on this site. I still have some of the Lewmar ports off of our boat.
view29
You're right, that's a lot of ifs but I'm happy to look. But you'll have to point me there, not familiar with the site yet.
Jackfmcc
Thanks a bunch!
Had the same situation on my E 27. Sliding Port light on starboard side in head did not operate, and one pane was broken, see photo. Took it to Local glass store , and they removed old panes, and separator, and replaced with single pane. See photo. Haven’t re-installed yet, but looks much better. Now matches smaller port light on port side of cabin.
Jerry VB
On my E27, I replaced both the forward portlights with "Lewmar Standard Rectangular Size 1 Opening Portlight" They are slightly larger than the factory portlights so you need to enlarge the hole, but that is pretty easy (I used a "RotoZip" rotary cutter tool). The originals are 5 1/8" x 13 1/8". If you want a non-opening one, you can have the one in my garage (I'm not a hoarder, honest, I just keep everything).
Cutout: 13-5/8" x 6-3/4", 2-1/16" Corner Radius
Overall: 14-7/16" x 7-1/2", Hull Thick.: 1/4" - 1-3/8"
Materials: Anodized Aluminum Frame with Clear Acrylic Lens
Ref:
paul culver
If you want a duplicate of the original slider port you can have it made at Bomon (not Bomar) in Canada. I'm happy with mine.
view29
Wow, thanks for all those reply's, that's very helpful! Someone gave me great advice to find a site with Ericson owners!
Kevin A Wright
I took out the slider in the head of my E27. Drilled out the pop rivets, had a glass shop cut me a piece of tempered glass for a one piece replacement. I'd already ordered the replacement gasket from Wefco since I was redoing all the ports. Put it back together and replaced the pop rivets (use lots of hot soapy water and clamps). If I'd known a glass shop could do that for me I'd have happily paid them to do it since it's a pain in the a** to get it all back together right. Just never thought to ask.
Kevin Wright
E35 Hydro Therapy
