Hi All,
I love getting the backing of the collective wisdom here before I drill/cut/remove or what have you. So thank you all in advance.
I am considering replacing two of my cams with a double clutch. I've attached some photos. The line shown is for the centerboard. The line not present is my main halyard. In one of the photos you can see the current situation for backing of both the winch and the cams. Seems less than ideal. only one of the two cams has a through bolt. There seems to be an empty hole and I presume the other three cam screws are wood screws into the wood deck mount. My thought would be to remove cams, install clutch with through bolts (4) with washers and locknuts.
1. Any reason not to do this?
2. Appropriate backing for either the cams or clutches? Through bolts with washers enough? or Add an aluminum plate for the whole winch/clutch assembly?
Thanks much for any input.
