Replacing shaft log hose
JPS27
I thought this process was straightforward. Mark both sides to coupling to know how they got back together. Take shaft side coupling off. Release coupling from shaft. Pull shaft back to get hose off replace hose, but back together.
However, I've been told that if I take off the shaft-side coupling to release the shaft from its coupling, I will likely need to get the shaft and both couplings re-fitted by a machine shop? That seems radical to me. I just need to slide the shaft back about 6 inches to replace the hose. I haven't done this before on this boat (not an ericson), so I still need to think about the space available to work on and remove the coupling, that space is tight. But if I can get the shaft off the coupling, I have plenty of room to get the hose off and on. At this point in my current boatyard experience, I do NOT want to have to take the shaft out for re-facing... that would mean probably dropping the rudder etc etc etc.
Thoughts? Thank you,
Jay
During dripless shaft seal replacement by a boatyard, my prop shaft was discovered buggered within the coupling. Shafts are tapered, with a keyway. Such damage is said to be common after many years. The coupling itself is often/usually/always rusted and in need of replacing. Yes, on my model the rudder had to be dropped for the job.
Your plan is worth a try, but I'm not sure my issues were unexpected or radical.
Way down in the article there is a discussion of coupling fit.
