It's raining out here in the PNW, and I've discovered that I'm getting a small amount of water in the bilge which I think is coming from the cockpit locker. Time to rig up a tarp...
The problem, however, is that I've got lazy jacks and a topping lift which makes it impossible (as far as I can tell) to drape a tarp over the boom. I'm thinking of running a line from the gooseneck or somewhere slightly aft of that, under the boom and over the dodger, and then affixing the end to the split backstay. That way, I can drape the tarp on that line, under the boom, and cover at least the aft part of the dodger and a good portion of the cockpit.
I'm not convinced that this is the best solution as I'll probably have a fair amount of unavoidable slack in the line.
Is there a better way to do this?
