Hi All,
I recently posted regarding a cyclical vibration I'm getting.
"It cycles on and off on with a regular rhythm. It lasts maybe 3 seconds, goes away for 3 seconds and then comes back for another 3. I do notice it happens more when the boat rolls from side to side. I just pulled the boat, did the bottom & replaced the zincs thinking the zincs might have corroded in a way that would throw the shaft off balance. The cutlass bearing was tight with no play & the shaft spins easily by hand with the engine in neutral. I haven't checked the the engine alignment or the motor mounts yet - that's my next task."
When I hauled the boat this past week, I could take the rudder & move it back and forth a bit & I'm wondering if this could be the cause of this type of vibration. When I'm standing at the wheel, the vibration seems to come through the cockpit floor & especially when my foot is over the emergency tiller access port which makes me want to look at the rudder. I guess the first thing I'll try is the grease fittings on the rudder post bushings then go from there.
Any suggestions?
Steve Gabbott
E35/3 "Silent Dancer"
Vancouver
Any suggestions?
Steve Gabbott
Vancouver
