Andrew Means
So my E27 has an aluminum tank that got a bunch of 'varnish' inside and it ended up killing at least one of the three outboards which have seen service on the Wino Country Safari (and being a prime suspect in the other's demise).
We switched to portable plastic tanks, which work fine but aren't large, and have to be re-filled in the cockpit while we're motoring longer distances (which invariably involves spills).
So I'd like to replace the tank with a new plastic one, but it is presently half-full of 2 year old gasoline and I can't really figure out how to get the gas out. Siphoning it seems like the simplest thing, but I don't know how we would get a plastic tank any lower than the aluminum tank, and we'd have to use a bunch of different plastic tanks...
Is there a way to pump the gas out of the tank? Anybody got any ideas?
Once we get the tank dry(ish) I'll want to remove it, and I think that will necessitate some cutting - what's the best way to make sure there aren't fumes waiting to blow the whole boat up?
