Secondary fuel bleed screw threading stripped.
Jeff Asbury
Principal Partner
Got her done.
Got her done. Took all of 20 minutes to swap out the old one and bleed the lines. I did as suggested earlier, and lightly sanded the copper washers with 220 grit, tightened and loosened and re tighten the fittings. The only hard part was the location was a little tight to get at, but I used a very small ratchet wrench with 10mm socket to un bolt from the mount, I was able to disconnect the banjo fittings with little turns with a 19mm open end wrench. I had just never dealt with banjo fittings before. All is good, no big mystery.
I did replace the fuel filter assembly with a new one though. I may try to repair the old one and keep it as a back up or sell it at a Nautical Rummage sale.
The worst part was trying to save $ by dealing with that useless online shipstore.com. I should have just dealt with my local supplier in the first place. Doing a Santa Sail for Christmas. Thanks for all the help!
Happy Holidays All! :xmas_grin
