Shifter and Throttle Cables
southofvictor
I believe that screw only holds the Delrin bearing in place and is not intended to be adjusted for resistance in the lever, but I could be wrong.
FWIW Edson calls the part “throttle friction adjustment screw” and I’ve used it successfully to do just that. It’s only on the throttle side. But if Windblown has a
YS pedestal it’s a moot point.
