Some random thoughts :
A recent engine upgrade is a big plus.
Sure looks like a wing keel to me.
It would be nice if there were a photo of the nav desk. Having a new radar is a big plus. Interesting that the primary display for that is a tablet. What kind of chartplotter is there? Looks like original Datamarine instruments in the bulkhead. Even IF they're working, they offer precious little information for the real estate they take up. Seems like the instrument package is a bunch parts that don't communicate with each other. People cross oceans with less, but I like our integrated system.
Check the dorade and the inside fascia panels in the cabin under it. This is typically a fail point on 35-3s. The cabin top inside the dorade box usually wasn't glassed or sealed. The wood rots and water leaks down.
If the liferaft is in good shape, that's a nice comfort. For the coastal cruising we do I'd rather have a good working dinghy.
Check the condition of the sole. If delaminating and spongy that's a huge project.
When you do the haul out for the inspection, check the shaft strut for stability. A number of us have had to rebed that. Also cutless bearing integrity, shaft true, etc, of course.
This is not a big thing, but I'd want the solar panels on more securely. Professional installations have edge flaps that velcro over to keep wind from picking up the panels.
What kind of battery bank is powering the boat?
Looks like the opening portlights are Lewmar. Our '86 has the Bomars. I've rebedded them but ours will need replacement in the next 3-5 years (I hope no sooner). If there is compression in 'your' aluminum frames I suspect there was leakage and someone tried to reduce that by cranking down on those screws. If rebedding portlights has not been done, it's likely in Lulu Grace's near future. There a couple good
master threads on this.*
Would you replace the alcohol and microwave set up with a propane stove/oven?
I agree with Loren, that the "other details" write up is way long on hyperbole and soft on hard (or even accurate) data. LOA and Beam are rounded off enough to be of little use.
Have you owned a boat before, or been active in maintaining one? Do you expect to do most, much of the work yourself, or will you hire the work out? Are you going to stay in the Great Lakes or will you be going salty, too?
FWIW - It looks like it's worth pursuing, to me, from way out here in the peanut gallery. I haphazardly watch ads for 35-3s. The asking price in August '24 was $39K and in December it was $38.5K.
Good luck!
* Master Threads: Christian has compiled a great resource in this list. Look through it carefully. It is a valuable guide for what to look at while inspecting an Ericson for sale.
Master Thread in a title identifies a full discussion of a popular topic. Posting to a Master Thread keeps topical information together. Autopilot Installation (Electric) https://ericsonyachts.org/ie/threads/38-200-below-deck-linear-drive-installation-autopilot-master-thread.12103/ Bilge Pump...
ericsonyachts.org
