While installing the alternator bracket retrofit kit, I also follow Christian’s Universal Diesel Wiring Modification’s Change A. The alternator output is now connected to Starter (+) terminal. I also relocated all the ground wires attached to the exhaust manifold to a newly installed ground bus bar.
Naturally the next step is to replace the ammeter with a voltmeter, and that’s where I ran into accessibility issue. The cockpit instruments was relocated to the coaming and I can’t reach the back of the guages. Even getting into the locker is a challenge for me. I read that another forum member 3d printed a new panel so that’s a possibility. Therefore if I am willing to 3d print new instrument panel, and instead of deleting the trailer connectors I am thinking of rewiring the entire harness from the engine to the instrument panel similar to Kenneth K’s panel upgrade. Should I,
A. Keep the cockpit instrument panel at its current location, but 3d print a replacement with larger flange and double the screw holes so I can use butyl tape as gasket instead of caulking thus make the panel removable for service.
B. Relocate the instrument panel back to its original location for better accessibility.
C. Relocate the instrument panel to the binnacle.
Temperature gauge stopped working a couple weeks ago so there’s a much stronger motivation to access the the back of the panel and fix that gauge than passively accepting the inconvenience of not having an ammeter/voltmeter.
In the photo, I've already removed the protective clear T shaped panel cover.
