markvone
The boat had a leak at the deck/head bulkhead tie down fitting that water stained the teak plywood veneer. This is in the v berth on the forward side of the head bulkhead so not very visible. I know I can replace the plywood (not happening) or cover the area with new veneer but I'd like to try and deal with the staining first. I've tried wood bleach on stains on the sole with no results. I've got the finish partially stripped off and plan to refinish the entire panel. No sanding or color staining attempted yet. Thoughts? Yes, I can refinish it as-is and live with it. The leak has been sealed.
Thanks.
Mark
Thanks.
Mark
