While sailing today... my port lower shrouds (on my E34) came off the mast and fell to the deck. Luckily wind was low and I had been too lazy to put up the main, so mast was not even strained. Still, let the sheet run immediately and then rolled in the jib.
Pretty irritated; standing rigging was replaced 9 years ago (before I got the boat, but by a reputable place), and I have had it inspected regularly when I take the boat in. Not sure what failed, but maybe the end of the bolt through the mast, or the nut on said bolt came off... cannot tell from the deck (end of bolt now inside mast.) And yes, I guess I should have been checking more often with binoculars, though unsure whether this is something that would have caught.
Anyway... I am moving up my (already-planned) standing rigging replacement to... now.
--> Advice appreciated: what should I be sure to do? I know this is going to be financially painful (I do not have time to do the stuff myself), but worse would be to forget something that then causes grief...
Things on the list include:
Mast itself:
- Have yard check for mast corrosion
- repaint mast (it's painted, not anodized)... how important is that? If it's just cosmetic, I don't need to spend the $ for looks.)
- some paint on end of boom is bubbling (how bad is it if that happens? small area)... so check boom for corrosion, maybe repaint boom?
- new mast boot (current one leaks)
Standing rigging:
- replace everything with new
- chainplates... these go through the deck to tie-rods that run in front of the shelves in the cabin; not excited about digging into the deck to get at them. Thinking of leaving them alone... unless you tell me this is stupid.
Parts:
- new roller furling (Harken Mk IV Unit 1... but maybe go to Unit 2 or Ocean models... current one is very hard to furl in any significant wind.)
- all sheaves in boom/mast (c.f. comment re halyards -- this would be time to change to 5/16" sheaves if I really should)
- VHF coax with low-loss new coax
- new wiring for everything in the mast
- new VHF antenna
- LED tricolor/deck/steaming lights
- wind instrument
- will get new halyards and maybe reefing clew lines while I'm doing all this... current ones probably ~ 10+ years old. May not go to dyneema though -- cabintop clutches will not handle 5/16", and replacing those is just yet more expense... unless you tell me to reconsider.
** NOT planning to replace traveler or mainsheet tackle... unless that is stupid? That's an expensive tackle, so I just carry spares for a couple of blocks in case anything fails. But does everyone re-up these? Set is probably 27 years old. Traveler seems to be working fine (though I don't use it much, since that's a hassle singlehanded and tacking regularly.)
Extras: (depends on quote/cost for all the above...)
- add track for whisker-pole attachment
- add topping lift for same (not a Kenyon spar; there is no current topping lift)
- I have two jib halyards, but no spinnaker halyard/crane to lift it out past roller furling. Is this worth setting up?
Anyway, suddenly planning to get this work done sooner than anticipated, and any suggestions/thoughts/advice would be deeply appreciated.
PS: Wasn't sure if this should be a new thread, or appended to this one. Decided to try new for ease of discovery by later searches, and to keep the other thread from exceeding 4 pages... but feel free to tell me to move it to the (very helpful) existing thread, which is
ericsonyachts.org
Mast itself:
Standing rigging:
Parts:
- new VHF antenna
- wind instrument
Standing rigging estimates?
I will restate that 17K is a very hefty sum for this type work Only if you can't afford it. The cost for having 'stuff' done on boats is somewhere around $150./hour. Give or Take (probably depending on where you are, as well). It does not matter to the worker if they are...
