    Join us on February 21st, 7pm EST
    EY.o February Zoom Meeting
    February Meeting Info
Steering pedestal replacement
Hi Dave,
We need a little more information. Are you posting your project? Do you have questions about how to do it?
Also, it would help folks respond more usefully if you add your model number, year, and engine details to your signature. Click on your avatar/name in the blue bar up above; go to 'signature' on the left side. If you're who I think you are, it's a 35-3. :)
As Jeff points out, paraphrasing....
a thread title with no content will attract nothing but puzzled glances.
Did you click on the "post" icon clicked too soon?
And yes, please fill in your Sig Line.
Thank you.
davehi
Thanks Jeff and Loren
This is all new to me
Hi folks. The Meriman steering pedestal
On my boat has deteriorated and needs to be taken out
I was thinking of replacing it with one of the square shaped Edison pedestals
Any advice is much appreciated
Dave
Pictures help. What's the problem with the existing pedestal? If it is a corroded base, there are workarounds.
Most of our boats rigged originally with Yacht Specialties/Merriman steering units still function pretty well. Parts however have to be second hand, as Ys/Merriman is long out of business. Edson parts are usually not compatible.
Changing the whole system to Edson will be expensive. There may be repair options.
Here is a photo guide to such pedestals, with links to Edson.
KS Dave
Dastardly Villain
If you decide to go the repair route, reach out to Anchors and Oars/Sailboat Parts in Grasonville, MD. I've had him ship me several parts to Kansas. Tell him what you're looking for and if he doesn't have it currently, he can keep an eye out from future boats he salvages.
bumbugo
I just received a Merman/Yacht Specialties Pedestal from Anchors and Oars. It's an exact match, the cost was incredibly inexpensive. Anchors and Oars was very responsive as we worked through measurements and options. Our existing pedestal in corroding at the base at all the two of the bolt holes - the damage most likely hidden by paint and bondo prior to the PO taking possession. Happy to have the replacement but not looking forward to the installation. Give Anchors and Oars a try.
I'll bet you'll enjoy the installation, especially if the replacement is an exact match. Getting the old one apart is only a problem if the big stainless machine screws into the aluminum on top are frozen, and you might not even need to bother with those. Do note whether your cable wires are currently crossed, so you can put them back correctly, not like I did. You've probably already seen pedestal disassembly and pedestal rebuild.
davehi
Here are some pics of the base. The right or forward edge of the base was repaired by po with some type of bonding material like JB weld?
Looks like the base needs to be replaced even though it does not move. I was lucky enough to remove the nuts on the retention bolts.
Letting CRC set in while I figure out what the next step is. Thanks for the Merman lead bumbugo.
davehi
Hi folks
Was able to remove the pedestal and have found a YS replacement
What type of sealant would you recommend for the bottom of the base to prevent water intrusion from the deck?
Chschaus
"Voila"
Hi folks
Did you replace the entire base and post ? I bought one from the same place and have yet to figure out how the post is attached to the base, I need to separate them as I couldn't find an exact match for the entire unit.
