TAFG hollow but not cored, right? [bilge connecting tubes]
Hagar2sail
Working in the bilge yesterday troubleshooting a bilge pump (turns out the pump itself was seized). While in there I noticed that several of the “pipes” (looks like PVC to me) that go between the bilges through the TAFG had partially slipped into the grid. This meant bilge water was free to fill in there if it got more than an inch deep. Looks like there isn’t any coring in the TAFG, so this isn’t a huge deal right? Or the fact that the pipes aren’t sealed? Also, were the pipes factory?
I had that situation on the 32-3. I concluded that the limber-hole tubes (apparently PVC) were there to keep water (rain water, stuffing box water) out of the TAFG structure and to contain it in the several molded bilges. My tubes had broken their bond with the TAFG and were just sorta lyin' there.
I didn't bother with a fix, because water inside the TAFG is inevitable, and with the tubes gone the bilge pump pumps out the TAFG too.
The fix would be easy enough. Just remove the existing PVC, insert new PVC, and seal in place with caulk. Or re-seal the old PVC. My current E381 has the connecting tubes still bonded, and that does pretty much keep the rainwater contained.
Still, mystery water gets in. To drain the TAFG itself my model has plugs installed.
Hagar2sail
I wish my bilge was that clean. Yeah I saw that picture of yours in the thread for the fuel in the TAFG. I don’t think I have any plugs, factory or modified.
So to be clear, the TAFG is just solid glass, against the solid glass of the hull. I don’t need to worry about saturated core in an inaccessible void.
Different boats seem to be configured in different ways in regards to connecting or isolating the bilge compartments from the TAFG. My Ericson 32-3 has 1-1/2" (roughly) holes drilled at the bottom of every bilge compartment (shower bilge excluded) to allow water to free-flow under the TAFG and between the bilge sections. Despite this, I also have the larger (roughly 2 1/2") PVC tubes located higher in the bilge compartments which carry the bilge hoses. Although there was originally caulk around these larger PVC tubes, I can't believe the caulk was to keep water out of the TAFG, since there are already drain holes at the bottom which do just the opposite. It seems to me that the caulk was meant to do nothing more than hold the tubes in place.
With the caulk missing, I got tired of the PVC pipes slipping into the TAFG while I was working in the bilge, so I've used screws to keep them in place. Re-caulking around the tubes is a pain.
If you look at both the drain holes and the larger holes for the PVC, there seems to be no evidence of coring in the TAFG--just thick fiberglass.
I looked at my 32-3 files again and you're right, Ken. The PVC is conduit. There are separate limber holes to drain the interior TAFG.
It's a little different on the 381. The TAFG bilge-connect tubes are sealed, and some compartments have removable drain plugs to empty water caught in the TAFG. There's no factory plumbing in the 381 bilge.
Re whether core in the TAFG, here's the hole for the 32-3 table support--3/4" thick and very solid indeed.
Hagar2sail
Thanks guys.
I like the idea of the screws to hold things together. Makes sense to me. A bunch of the black caulk was just sitting in the bilge. Now I know what it was from.
Tin Kicker
This was the through hull for the head discharge and the TAFG is from 0-3/8" on the tape. Definitely solid fiberglass. Same everywhere else I've cut or seen holes through it.
