Jim Picerno
1989 38-200
I was out sailing last week in moderately rough conditions (20 kn winds w/ gusts to 30 kn and unsettled sea state). We had a fair amount of green water washing over the foredeck. We were on a starboard tack for 3 hours when the bilge alarm went off, and we discovered water in the bilge almost over the floor boards. A stop in a nearby marina allowed me and my crew to troubleshoot the issue. The bilge pump had failed, and with an external pump we evacuated approximately 150 gallons of water. The water was salty so definitely sea water. I started looking for the leak by inspecting the thru-hulls, the engine compartment and shaft seal but the only water we found was in the chain locker, and not a lot of it. I replaced the bilge pump with a spare, and motored home the next day in calm conditions and had no water in the bilge. The likely suspects for this leak would seem to be the chain locker, or maybe resulting from us being on a starboard tack in rough conditions. Even with the bilge pump failing this was a large amount of water taken onboard in a short period of time. Anyone who’s had a similar incident or thoughts on the likely cause of this water ingress would be appreciated.
