Thru Hulls on 32-3
pick
I'm thinking of replacing the vacuum cleaner type cockpit drain hoses on my 32-3. Does anyone know if the white thru hulls are plastic or the better (Marlon?) stuff? Is there a way to tell? If they are plastic I'll have to replace them along with the hoses.
Thanks for any help on this.... Mike
which end...
Mike,
Are you referring to the above-water exits on the hull?
Material Matters
When we get around to replacing/upgrading these fittings on our '88 model I plan to change from plastic/composite to stainless steel.
Groco makes them, among other choices. They come in all the same sizes as the non-metalic ones, and I notice that a prominent local boat builder uses the SS ones for all of his projects. No more concern about UV degradation, either.
ps: here is one URL, out of several, with prices on all diameters, in 316 ss.
http://www.boatersland.com/thruhull.html
