Thru Hulls: Seacock bolted through the hull or ball valve??
1974 Ericson 35-II
Preparing for my first haul out for the bottom paint and I thought this was a good opportunity to get rid of these thru-hulls with wood backing blocks. I talked to my yard and its $1000 per hole to do the work. I planned on replacing like 5 thru-hulls but $5000 for this job is not what I wanted.
The real question. If the job was just to remove the original thru-hull, add a "plastic" backing plate and tighten, obviously using maybe 5200 I would feel fairly confident in doing this, and then just spinning on a new bronze in-line ball valve by Groco.
I have read that the only way to do this job anymore is to use a seacock which requires drilling through the backing plate, the hull and bolts to the outside of the vessel. I get this is a much more secure install but is the first method wrong or dangerous? Its whats in my boat now and seems to have held for 40 years.
Thanks in advance for any answers!
That yard must want about $200/hour per thruhull. Seems quite pricy to me.
For a backing plate I am a fan of something that is strong and rot proof, like G10 composite. Note that terminology matters. A "seacock" fitting is a valve body with molded-on flange and that flange or base is attached to the hull. i.e. one piece.
This is much much stronger than having a ball valve screwed onto a thruhull fitting, whether it's made of bronze or Marelon.
I know of three ways to attach a seacock.
1) traditional way of boring thru the backing plate and the hull. Chamfer the hole on the outside so that a bronze flathead bolt is flush with the hull surface. Set in a lot of 5200, this should never leak and you can fair over the bolt heads before applying bottom paint to that area. Ideally the actual bronze thruhull fitting is also flush mounted to the outside hull.
2) Same except that the inside plate of G10 (about 1/2" thick) is glassed to the hull after having the valve mounting holes drilled and tapped into it - but not extending thru the hull itself.
3) Use a Forespar Series 93 seacock with the flange base. Screw in the outside Marelon thruhull fitting, set in epoxy mush. Also have epoxy mush under the G10 plate inside and under the seacock. After the epoxy cures grind off the outside lip, flush with the bottom. FWIW, this is how all of our Forespar Marelon (series 93) seacocks were installed in 1995. Still work and look like new. Since the Marelon material is a fiber-reinforced resin product, I figure that it is a strong as our FRP hull, and the fittings and the hull are become "one." :)
(3a) There is a competitor for Forespar nowadays and they seem to also have a decent rep, although I forget their name.
The reason for using a true seacock is that ABYC requires these fittings to withstand a side shock load of something like 200#, like when a lurching tool box whacks into it when the boat does a hard roll to one side or the other. I believe that Rod Collins has done some testing of thruhull fittings and written it up for his site. https://marinehowto.com/replacing-thru-hulls-and-seacocks/
Regards,
I think the other similar company to Forespar is called Trudesign, and they make a collar that goes around the seacock and will apparently withstand a 500 lbs. force to comply with the ABYC standard. They have Teflon inside, so don't need greasing, and mine have worked as advertised for the past three years. They are alot cheaper than bronze, and don't corrode.
nukey99
General alert to thread compatibility:
I found that out 35 years ago, when I tried to screw a ball valve on to a thru hull and it would not thread all the way down. A diver had put a plug in the hull on the outside while I did the work. This lead to a frantic trip back to the local boat yard to get the correct (and more expensive fitting).
Here is another option that eliminates the mismatched thread issue:
I replaced all thru hulls and backing plates with new bronze fittings, 1/2” G10 backing plates, these flange adapters and bronze ball valves. Now if a ball valve fails I can easily replace it without disturbing the thru hulls. As per Loren’s #2 point above, you don’t have to drill through the entire hull, you can simply tap threads into the G10 plate and use bronze studs (cut off the heads of bronze hex nuts). You have to cut the thru hulls to proper length too but that’s easy with a hacksaw. It’s a bit of work but eliminates a major worry factor.
Here’s a photo of the sink drain thru hull assembly (before installing all the hose clamps).
JSM
Groco makes a backing plate for use with their flange adaptors. Looks like it would make it a fairly straight foreword job to install a new thru hull and valve assembly.
G Kiba
I had thru-hulls and valves replaced in 2005 on my 73' Ericson 27. Labor costs and parts have become outrageous in the last 2 years.
This is true for so many recreational activities. Have you seen the price of bicycles?!
I have found that... If you can't do it yourself; or if you are not willing to learn; or if you don't want to take a risk, or if you can't or don't have the time to spend doing it yourself; or don't have the right tools; then, the best choice might be to have it done. And even that is no guarantee that all will go well these days. At least by having it done, you are supporting the people in the marine industry. I expect that as prices get out of our reach, there will be fewer of us spending and the prices will continue to climb.
Ok! These are all great responses. It seems the best route is to use the real deal seacocks. I always can get the tools for the job. This one specifically sounded tedious and I have other tasks I wanted to attend to while the yard worked the thru hulls. I think it is going to be cheaper to keep it dry an extra week and just do it all myself and pay some folks in beer to lend a hand. Everything I have done to this point has been a learning experience and probably the main reason I love having a boat. Wish me luck! If I can remember I will update this thread with the results but that’s in a couple months.
gabriel
Live free or die hard
1974 Ericson 35-II
The groco backing plate comes with threaded inserts so you don’t have to drill into the hull, it’s not nessesa . Glue the plate on with epoxy not 5200.
I put a large G10 before the below the groco plate to add stiffness try and stop the hull from flexing (tuna canning) when I load up on the trailer. I know, it’s an overkill.
A trick to screw the thru hulls in from the outside: instead of purchasing a step wrench, find a chisel or other robust straight tool that fits between the ears of the thru hull and attach a pair of vice grips for leverage. You can also find a socket of the correct OD to fit in the thru hull opening and then cut a slot with a grinder.
Post in thread 'How to Replace Through Hull Handle'
https://ericsonyachts.org/ie/threads/how-to-replace-through-hull-handle.14636/post-104406
I will be an outlier here and just say that I think the Groco three corner bolted through hull fittings are needless overkill. It is true that the marine ball valves and the fittings can spring leaks (I have experienced two pin hole leak situations on deliveries). My view is putting more holes through the laminate is a serious downside to most recreational hulls--considering the thickness of the hull material and the quality of most factory layups--most of these underwater through hull fittings are not located where you are likely to drop an anchor on them--Ericson put plastic and nylon through hull fittings on all the above waterline places where you would be most likely to break them. The Grocos are scaled down from the stuff they make for tugs and commercial craft where the danger from shifting cargo is much greater. I think a nut with hunk of G10 bedded in thickened high density filler works well. I have coated the through hull fitting with mold release wax and set it in the high density filler, then come back the following day, and set the whole thing in 4200 and threaded it back in and tighten things down. This seems a tighter solution than jamming the fitting through a hole and hoping I put enough sealant around it. I also do not use 5200 on anything you might possibly need to take apart and 4200 is quite adequate for through hull fittings. I am looking out for the next guy who has to replace it. Just another point of view.
I agree these are probably more robust than needed for our typical use case. I decided against bolting through the hull for this reason. I used the adapters primarily to overcome the thread mismatch issue. The added benefit for me or a future owner is how easy it is to replace the valve if needed without replacing the entire thru hull. Even replacing the thru hull itself would be easy from the outside with the flange adapter bolted onto the inside of the boat. When I replaced all the thru holes in 2016 the adapter and the valves cost a bit less than the full seacock assembly, but I see they are essentially the same cost now.
And, while on the subject of overkill boat projects, may I offer this example
This is the head compartment where I tried to retain flexibility for future head system installation. I should have just glassed them over since I’ll never use them.
The countersunk thru hull fittings cost extra at a yard to install because they are more labor intensive. The ones that stand proud are cheaper because there isn't a lot of prep work compared to the countersunk ones. I'd be interested to see if that $1000/per thru hull is for countersunk or not. In my opinion the countersunk ones are a waste of money on cruising boats.
Also what on earth are y'all storing around your thru hulls that weighs enough to snap them off in big waves?
Doug makes a good point about the perceived perforrmance value of the flush thru-hull. That was one (small) reason we signed off on the epoxy-bedded install of the Forespar Series 93 design. While they do have a lip when installed, it is ground off flush after the epoxy kicked. That was back in the 90's, and they all still work fine. (and look like new)
FWIW, in very light air a flock of thru-hull outside flanges might reduce speed by a partial nano knot, maybe.
I'm in this decision making process now. I have started acquiring parts and so far I've gone with the Marelon thru-hulls and Seacocks. In my head I also have unused thru-hulls and seacocks that I will likely replace for future owners or in the case I ever need a outlet for my blackwater.
gabriel
unless is changing from one type to the other, which requires either glassing-in or removing material to make way for flange, how would flush ones be more labor intensive?
what you are saying is completely true I agree, but with the cost and effort being virtually the same, why not? what can it hurt?
gareth harris
The only reason I can think of for screwing in the sea cock flanges is to prevent them rotating, which will not need much torque so screwing them into the backing plate ought to be ample, leaving no need to make extra holes through the hull. It is what I was set up to do before my project ground to a halt.
Bronze vs. Marelon has long been discussed on here. I am not qualified to be the arbiter, but bought bronze for its solidity.
The performance advantage of flush through hulls is greatest for those forward in the hull since turbulence increases as the flow runs aft, but an Ericson is a performance boat so I installed flush throughout.
Gareth
Freyja E35 #241 1972
