transducer
I cut the cable (after gritting my teeth) at the transducer and patched a line straight to the data marine df. It still read 3.8'; i wondered what it would read without any input from a cable...3.8'. I hate to drill new holes to run a new cable; i might bite the bullet and remove the starboard water tank; it's the most likely suspect. I haven't messed with the transducer or the cabling prior to this; it functioned great til last summer (at the Cheasapeake Ericson raftup; now that was a great party!) Next day i dived in and found barnacles on the transducer; so that's where the erratic readings came from; after, it was improved; then i read about advancing the gain; thru the rest of the summer and fall; it worked very well. On haulout, i saw a barnacle base left on the transducer; well, now it should be flawless. On launching this spring, the df read 3.8' consistently. Tom; do your df and speedo cables move freely inside the hose?
