1911tex
There are details on the following method elsewhere on this forum if you search belt tension; maybe 9 months ago or so. Its a very easy and very accurate way using only your thumb and first finger. Grab the center at the longest distance between pulleys and twist either direction...should never be able to twist the belt more than 90 degrees. Tighten or loosen to hit the mark. No crowbars, boards, tools, etc.. Surprising how many automotive mechanics use this simple method which takes a second or two or spur of the moment. There are many videos by mechanics on YouTube describing this very common method.
Here are only a couple:
If you can put up with this dude...good advice:
