James Carlisle
For years I have been using a universal rubber funnel connection when pumping out the holding tank in my 1985 Ericson 32. Lately I've started to research the proper thread size of the waste connection on the port side of the boat with little luck. A 1-1/4" npt NozAll Pumpout Adapter is too small and the 1-1/2" is too large. Our pumpout fitting is 1-1/2" diameter and that seems common. Measuring the fitting cap from the boat matches the 1-1/4 npt specs at 11.5 threads per inch but still cannot find an adapter that fits. What gives? Is there a special addapter required? There are no fittings that I know of between the two sizes mentioned. Thanks for any help you can offer.
Jim, Hull#637
I suppose that replacing the fitting is an option but, why would they (Ericson) use such a fitting that employs a running thread fitting when all plumbing fittings are tapered? Why is it larger than 1-1/4 inch and yet smaller than 1-1/2 inch? It does not appear to be metric. Does anybody know what fits this thing? Is it available?
Jim, Hull#637
