Water in thru drains on E34T
Michael
Does anyone know how to eliminate water from entering the cockpit through the cockpit drains, while heeling?
This is a 1978 Ericson 34T, and when she heels past 18 degrees, a siginificant amount of sea water enters through the leeward side cockpit drain. When she flattens out, the water drains away.
I've checked the thru-holes [location=low center transom, behind rudder mount] and checked plumbing, and all seems normal.
I've concluded that this is basically a design-flaw, but am not certain. The sea water that enters is always at or very near the waterline level at heel.
What, if anything, can be done about it?
Same thing happens when "rail down" going full tilt boogie to weather on my friend's E-33 (Holland design). He has a T shaped cockpit and this only bothers the driver standing in the low side of the "T".
Others boat makes solve the same problem by crossing the drain hoses on their way to the transom -- only down side with this is that it will slightly slow the draining of serious water from the top, like the greenie you took over the combing.
:rolleyes:
If the water is only about an inch deep... you could use this an excuse to put in a grating over the cockpit sole and "class up" the boat and raise your shoes out of the water.
Well, it was just an idea....
Best,
