mbp: I just listened to Cote's video, thank you. He is horrified the way we wire our alternators. We wire them switched...i.e.; alternator to starter solenoid to master battery switch to battery bank. He recommended only wire unswtitched...i.e.; alternator directly to battery bank! Now I am trying to figure out how to rewire??
Sounds great, but nothing is free (especially when it entails re-wiring your existing system).
If you wire directly to the battery, you also must install proper fusing on that line (which is likely a smaller line and, thus, a smaller fuse than what you would have on your main battery cable fusing. That's if you have main battery cable fusing, which Ericson did not install from the factory.
Even if you wire & fuse directly to the battery, you've now created an always-hot line (with a LOT of amperage) between the battery compartment and the engine compartment. Most wiring schemes that do this also add an "alternator disconnect" switch to disable the hot line while working on your engine and/or alternator. So, it's not as clean and simple as it sounds at first. If you happen run your engine with the "alternator disconnect" switch off, you've created the same problem you were initially trying to solve--frying the alternator by having the switch that connects it to the battery turned off.
Like they say, you can try to idiot-proof something, but they never seem to stop inventing better idiots.
