I know, I know! Hate to replace the damn thing...
It's a tough day and I just need to went, so while the content below is correct, please do not pay attention to the style
OK... The only zink on M-25 is in the heat exchanger (the tube with 2 hoses, typically attached to the back of the engine, over the transmission). If you have a standard issue exchanger, it should be somewhere around 2 to 3 inch in diameter and about 1.5 feet long. The zink is on the right bottom side of it and looks like a hex bolt sticking out, and typically its bronze (ours was painted over). Found it? If not, check the left side.
Close the seacock that lets the raw water in, and carefully unscrew that zink out. Mine works well with 7/16 socket wrench. Watch out - there is tons of sharp metal around, so watch your hands. If it's been long enough since the last replacement, you will only pull out a bronze head witout any traces of the actual zink. Or some zink ashes inside the head.
West Marine typically carries an assortment of these so-called "pencil" zinks. Find the one of the right size. Now, bring it to the boat and make sure the length is right, too! You may have to end up cutting a piece of tail of that zink off.
Now, put some teflon tape (or, better yet, plumber's paste) on the threads and screw the new zink in. Make sure it's tight or it will leak.
Phew! Done! Go get yourself a beer. And don't forget to open the raw water seackock before you start the engine next time...
Regards,
Stan
