Angel D.
Hello Friends , hope everyone is well .
Here is a couple pictures of my windlass install on Yiyi.
First step was removing the core on the hatch of the anchor tray , then beef it up with glass and honey comb to give it structure. Then made some PVC mount to follow the encumber and sit the machinery
After it was line up it was time to make the holes and set up the top hatch.
When it all line up was a happy day and the encumber PVC work perfect ,... after a lot of sanding and try outs that is.
The bottom side has also a three quarter inch PVC base and aluminum plate quarter inch thick . Extra structure made by soaking lines on resin and molded with thickened resin.
Took the chance to upgrade the cleats with a better backing plate .... the upgrade is substantial and very happy with it.
Only the outside is accessible but is a great improvement . I think they are better now.
Then sand up all the edges and thickened resin all around the edges. Note that the windlass was installed on the lid before it . This way only need to get inside the locker for wiring the motor, and that motor is not light . Also the U bolt that used to hold the chain was really strong , so I use it on deck and it goes trough the aluminum plate as well.
The wire was done and a quarter inch plexiglass was used to keep the chain to open the door access to the locker .
