WTB 3 sheave deck organizer
driftless
Has anyone replaced their deck organizers and looking to part with the old? Preferably a 3 sheave. Hopefully compatible with the "Lewmar Spinlock" pictured, as I'd like to stack the 3 on top my existing 4 sheave.
2" sheaves with axles 2.25" on center, I believe.
Alternatively, has anyone found compatible deck organizers that stack on these? PXL_20220430_183038230.jpg
I'm very curious about the history on the Lewmar/Spinlock marriage/divorce that is evidenced by the name stamped on these.
cruis-n
Something like this? I think I have 2 but only found one after a cursory search.
Those look like the OEM Lewmar 'organizers' I replaced (same hole measurements!) with new Harken's. I sold my old Lewmars after finishing our re-fit. The newer Harken designs are ball bearing, which is a Good Thing.
driftless
Check ebay. I've found such parts there.
No such luck with this search Ken, at least so far. I've scored some real gems in the past thought. I'll keep watching.
Something like that, but not exactly that. I'll doublecheck my measurements this weekend, but I believe yours is oversized to fit mine. I'll let you know. I only need one. I really appreciate you looking and the photos with scale.
Very good to know you found Harken to match the hole pattern Loren. I'll replace them if I can't find a used one to match. I know friction is the enemy, but the lines make a fairly slight bend around these sheaves. With bearing blocks elsewhere I don't seem to be fighting too much drag currently.
driftless
I remeasured to be sure, and the hole pattern on your organizer doesn't match. Thanks again for offering!
Will likely end up buying Harkens.
