In response to comments on the previous blog entry. Yes! Access to the quadrant is easy. You do have to lie on your back, but you can scooch right up under it. I constructed a shelf to fit over the fuel tank which is mostly the same level as the quarter berth. Eventually I may put a water heater in there which would disrupt access, but for now it's good. You could even cut further back along the panel to get more access...
