E25CB Ericson 25 CB build - Rudder rebuild
As usual, what I thought would be a quick fix ended up being more involved...
23605.attach
One of the strengths but also weaknesses of the Ericson 25CB is the outboard sits in a transom cutout which will cause the prop and rudder to collide if steered hard to port while under power. Previous owners did this and caused gel coat damage on the starboard side of rudder. Fixing this prop damage is how the...
You do not have permission to view the full content of this entry. Log in or register now.
Blog entry information
Author
gabriel
Views
558
Last update
More entries in Hull, Deck, Keel & Rudder
More entries from gabriel
