Took on a bigger project than I bargained for.
The initial reason was water damaged/rotted sidewalls and some damage to the headliner in the main cabin. Figured it would be no big deal to replace the wood and rebuild the headliner. Not exactly the case.
Things I've learned:
1. Multi-tool oscillating saw was the best approach I could find cutting out the rotted wood. Converting to a scraper blade allowed me to peel most of the wood away from the fiberglass cabin walls.
2. I was able to use...
You do not have permission to view the full content of this entry.
Log in or register now.
