Marine Diesel Cooling System Upgrade 2020
Symptoms: Apparent decrease in water volume at exhaust. Temperature RPM limitation at Wide Open Throttle. Steam from exhaust at idle. Solution: clean heat exchanger, optional general upgrade. [Note 2024: For routine maintenance of the cooling system I later had success with the immersion...
