Back a couple decades ago, I replaced the factory hardwood wedges. They had put in four, with longer ones on each side. There were "corner" areas with no wedging/support, and it seemed like there should be more continuous support all the way around. I made these out of teak scrap and they are still in fine condition, so were reused.
Each one is L shaped so there is a 'shoulder' on top to keep it from dropping thru. As before, I put a layer of sealant around the top of them so they do not...
You do not have permission to view the full content of this entry.
Log in or register now.
