This time I used thickened epoxy on all the edges and let the first course cure before adding the reinforcing layers of biax. This turned out way better with much fewer voids.
Try #2
I filled the voids and spent hours sanding it flush. Then I primed it, but the primer cured lumpy, so I spent more hours sanding it smooth...
