Phr3d
Good morning,
It works sometimes. The power wire is attached. I found that when it doesn't work, if I wiggle the wire going into the pump, it goes back on. I did not take a picture of the pump so some of this is theoretical.
I'm wondering what I will find when I take it off. My suspicion is that the post that is internal on the pump is shorting. Is that user serviceable or do I replace pump?
Which brings me to my 2nd question: What size pump is the best compromise? 40 gallons of water / 3 or 4 gallons per minute means not much difference even with being prudent. I am thinking about if it is possible to put a water maker under the refrigerator/sink area so that the 40 gallons of fresh water can be supplemented...
