mherrcat
Background:
I discovered a trickle of water coming from under the fuel tank when the engine is running. It starts about one minute or so after the engine is started and it will slowly stop a couple of minutes after the engine is shut down. There is no leak from the exhaust system that I can see and no leak from the anti-siphon vent from the engine salt water outlet. The only place I can figure it is coming from is the hot water heater. There are two hoses going to the hot water heater from the engine/accumulation tank, but I can't see where they connect.
Problem:
I can get to the port side of the hot water heater where the two fresh water lines connect, but how can I get to the starboard side? There doesn't seem to be any way to do it. The boat is an E30+. The only access to that area is through the port side cockpit locker and the stern cockpit locker on the port side. (The starboard stern cockpit locker houses the propane tank.)
Sidebar 1:
What is the "accumulation tank" for? I noticed it on the boat and couldn't figure out what it was until I found it on the drawings of the system plans.
Sidebar 2:
The starboard cockpit drain seems to be clogged. Is there a through-hull fitting for that drain that has a valve? And if so, where is it? According to the drawings the port side cockpit drain connects to the galley sink drain and there is a valve there.
(Sorry for all the questions in one post!)
Problem:
Sidebar 1:
Sidebar 2:
