J measurement
You have to be very careful about this. How did you actually measure this? If you used the very forward face of the mast to a point equal in distance to where the headstay touches the deck, up vertically so that you make this a distance PERPENDICLAR to the mast, this "might" right, BUT the measurement WILL be affected by where the mast is located. In the IOR days, we used to move the mast around in the collar to "change" the J for rating purposes.
Also, unless changed for rating purposes, the spinnaker pole length will equal the "design" J measurement. Under IOR, the pole determined spinnaker girths, and the J determined headsail LP's.
In today's world, PHRF uses the "design J" and pole length for determining sail sizes, and my original sailplan shows a J of 15 feet.
All you will accomplish by building sails to 14.5 is ending up with a smaller sail than you are assumed to have by all of the racing authorities
If the pole is 15', you can safely assume that the "world" considers the J to indeed be 15 feet.
On a similar note, the "I" cannot be accurately measured by a layperson. In fact, there is not one, single, "I". IG, or foretriangle height, is roughly the intersection of the headstay and the forward edge of the mast. This is used to determine genoa sizes. The "ISP" is from the TOP of the spinnaker halyard sheave, and is always very slightly different. The BASE of I is technically the sheerline abreast of the mast. In reality, it is almost impossible to obtain this point precisely using a tape measure. All of these things can have an impact on IMS, AMERICAP, and IOR mesaurements.
For a cruiser, or PHRF racer, the default numbers we sailmamkers use are the DESIGN values from the sailplan. The value of an actual boat measurement is not that you verify the design values, but rather to verify the sails will physically fit the boat.
So, unless you plan on getting an IMS o Americap certificate, the I of the E-34 is 46 feet and the J is 15 feet.
Cheers all!
