Hello all,
So per my last thread, I tried a few things based on your responses (thank you).
Added a Groco Sea Screen.
Swapped out all hoses from Thru-hull up to water pump.
Started her up and she's still not getting water coming out the aft port and thus she begins to get too hot too soon.
The Sea Screen fills with a darker water as if the water is going in the wrong direction. Then I looked on the Moyer site and noticed the fins of the impeller are pointing in the opposite direction as ours.
Image 1 is off the Moyer site.
Image 2 is our last impeller that lasted only a few months.
Image 3 is the newest replacement that isn't working at all.
Is it possible that this opposite direction per installation is causing the water to back up and/or tearing up these blades?
